I bought i Chinese clone board, and yes. It SUCKS! The acceleration is horrible and the breaking is even more horrible. Therefore i decided to buy i VESC to replace the current ESC which i expect is the main problem. A guy on youtube, Dr. Circuit did this apparently with good results
After receiving the VESC and opening the board i have a few things I am unclear of. I hope you guys can help me out!
So here is my VESC and the ports i think i need to use. Also of cause the USB port for configure it.
I would like to reuse the bms and the controller. Is it possible, just to replace the ESC with the VESC?
also. the VESC has three pins to connect to the receiver but the receiver has that white connector with many ports coming from the ESC. Also. There is two wires coming from the ESC, soldered to the receiver board. What about those?
Ok, so from those pictures, i can asume the black and red are fan, the other 8 (cant really count them properly from the pictures) should be PPM(3 wires)+SENSOR(5 wires)
Okay. that makes sense too So, do you think i could just replace the receiver and add for example the 2.4GHz Nano Remote cutting the wires to the receiver board
