Hello!
I’ve built my board from this pre-bought one from Decathlon:
https://www.decathlon.co.uk/p/surf-fish-longboard-80-cm/_/R-p-5920
I’ve already replaced the wheel for some 80mm Orangatangs and I’m quite satisfied with how the board handles at low speeds. But when going to higher speeds(30km/h+) it becomes a bit unstable and I’m not confident.
I was wondering if upgrading my trucks to Paris V3 180mm would improve stability and how would that affect my turning ability on tight corners?
My truck width is already at around 180mm probably as the distance between the inner parts of the wheels is 150mm. The angle is also 50 degrees like the Paris trucks. The bushings are 92A
