Selling my DIY Trampa build (US ONLY)
Includes: Trampa HS11 Deck (New condition) 16in Ultimate Trucks w/ 9.525mm Titanium Axles, Gunmetal hanger, White Springs, Red 80a Dampas (CNC Trucks new were $130 a piece) Light wear on bottom TB 110 Wheels with Trampa bearings (Wording warn but have full tread and wear evenly) TB Reverse long motor mounts Dual Flipsky 6374 190kv battle hardened with epoxy and glass micro-spheres and vinyl wrapped 2x 16t steel pulley 2x 18t steel pulley 2 sets of 36t kegal wheel pulleys 4x 320mm belts 4x 330mm belts All stainless hardware Wheel pulley bolts are zinc plated stainless Meilan X5 red rear tail light
Focbox Unity w/ re-soldered motor leads in 12 gauge and marine heat shrink with glue inside Housed in a pelican waterproof case drilled to the deck Flipsky VX1 Extra battery cable for good measures $1200 plus shipping
Sold Separate 2x DIY Eboards 10s5p 360wh $120 plus shipping each New Dicky Ho 6x2 set with 2 60t Aluminum pulleys. $110 plus shipping
Shipping cost depends on location and will get calculated before purchase Will remove trucks to protect motors during shipping
Let me know if you have any questions
