I thought i was being smart when I bought my BMS(es) with a separate chargeport (there was obviously a combined version as well). It is only now that i realise that a skateboards actually brakes using recuperation. So short story shorter: can a BMS with a separate port be used generally speaking?
That looks normal. If you are referring to the fact that it has the balance lead, you are fine. Every BMS has those exact leads and ports. I was going to get a similar bms, but it has a positive lead, negative lead, and negative charge lead. All BMS’s have the balance leads though.
Any clue then why the port is separated? After all thats would be just costlier, wouldn’t it? The weird thing with these BMS is that the ones with the separate Port are actually cheaper, which sounds like the were able to make the board simpler with the separation and thus drive cost down.
I believe you’re correct. It’s my understanding that there are two methods in which the battery takes in a charge current. The charge port on the BMS charges via the balance connectors, where the regen current comes from the ESC, which comes into the main battery connection (I believe this comes in as an unbalanced “quick charge”). I could be incorrect though, most of my experience in this involves building large lipo packs.
I’d be curious how the combined charge/discharge BMS variants handle the charge current input from a charger vs regen. I can’t imagine it tries to balance charge the regen current? And I would think the combined variant would be more complex and therefore be more expensive, but they seem to be about the same price. I’m by no means a DC power systems expert, anyone care to chime in? @chaka ?
Actually no charging takes place via the balance cables, they only bleed of the excess voltage when the battery is being topped off. They keep the high cells in check while the rest catch up. There are exceptions but the common BMS units work this way.
Usually a BMS will only be able to discharge a high cell at a very small rate, about 0.10 Amp per cell. Not much help when you have a full battery and you are pumping in a heavy regen current.
Wow, TIL. Quite different from the BMS modules we used to build out big lipo packs. That makes sense though, active balancing via regen didn’t sound like something these were capable of.
