Doing some Fall minimizing and have a few used items from previous builds for sale. Prices are in the item descriptions; pics below.
Set of MBS All-Terrain 100mm wheels. These have about 5 miles on them. They’re in great shape, but with a little cosmetic belt rash on the insides. $70 on Amazon plus shipping. Selling for $45 plus actual shipping to your place.
Hi5ber Raptor deck & Psychotiller Enclosure Combo . I loved this deck. I use to run it as a 4WD hub, but when I switched to belts, it just wasn’t long enough for 4 motor mounts (2 would be fine). It’s super light weight and very agile. Lets you lock in your feet, really well. It has almost brand new Vicious Grip Tape on it. It also has a Psychotiller enclosure that I heat molded and trimmed to fit the deck. The enclosure could use a little TLC, in the way of ABS glue on one of the screws holes. I over ratcheted and cracked the flange, trying to stuff too many components inside, for the 4WD. The deck itself is in pretty good shape, but it has been drilled, here and there. I filled in most of the unused holes in it with epoxy and sanded it down. Perfectly functional. The only extra holes are from where I extended the wheelbase. The enclosure has an LED power switch and charge port already fitted. That LED lights up white. New, that deck is $230, the enclosure was $60, and the electrics were around $10 or $15. I’ll let the lot go for $200 plus actual shipping.
10s3p LG HE2 25r - ON THE FRITZ. This was a Torqueboards 10s3p, purchased circa mid 2016. I wanted to use my own voltmeter and power switch so I busted it out of its original shrink-wrap and hot glue mess, added said components and re-wrapped it, in clear shrink. It worked fine, and has very few cycles on it actually. The problems started when I stored it for over a year. When I came back to it, it wouldn’t charge to 100%. I think the BMS is toast, for one thing, but it may also be out of balance or have a bad cell in a group. The last thing that happened, was when I bridged a couple of the BMS leads when trying to check the voltage, and caused some burns (see the pic). See photo for last recorded voltages, on night of the BMS short. I don’t currently live in place where it would be responsible to try to work on this pack, with my intermediate battery knowledge. I’d like to get $100 OBO, if someone wants to take this pack and harvest the cells or can bring it back to life. DO NOT buy this if you don’t have the skills to do that. Danger.
