Can I use a dual vesc to run a single motor? I have a GO - FOC DV4. I plan to run a dual motor on it but just waiting for another wheel pulley in the mail.
I don’t believe v4 supports this, but I’ve been wrong before.
Even the v6 way of doing it requires updated custom firmware.
I dont see why not… run motor detection on one side and set it as the master. Just keep the belt off and i wouldn’t even plug in the motor… make sure the loose bullet connecters on the side you are not using. stay safe and insulated and you should be ok
Oh, yeah. You can just use one side and leave the other side sittin’ there all vestigial-like. Thought you meant combining sides for one motor.
