I bought two v-esc from enertion boards the 4th of august 2015, and I just started tu program them.
Both are a 4.7HW version and have a 2.16 firmware flashed using a stlink-v2 plugged into the swd ( the bootloader was broken, impossible to update by the bldc-tool).
Both are working now, but only one of them heats up anormaly fast (i.e : Mosfets at 50 degrees rising, idle).
Is this normal, should I be worried about this? (the other one stays at 30 degrees )
About the firmware: Did you open conf_general.h and select which hardware version you are using before the make upload command? Default is 4.10/11/12 now, so it needs to be changed for 4.7 when working with Ubuntu.
I checked again and on the over heating one the DRV8302 is especially hot ( I can’t let my finger on it more than
2 seconds, I know it’s not a really precise mesurement, but I have not any thermometer with me to the place where I am right now ).
Probleme solved : A friend of mine took a look with a x10 magnifier and found a micro tin bridge between two legs of the DRV, removed it and now it works without overheating.
