First off thank you @mmaner for answering my questions and giving great advice .
@boardnamics mounts are great
@onloop the unity functions flawlessly. I am very pleased . I applaud you sir.
I could have never done this right with out yall and this forum .
This is my first build. It will not be my last.
Swapped the wheels new gearing is 16t/60t . idler still functions with some extended wheel spacers.
I was worried about that so I’m redrilling the front truck mounting holes on the forward most parts of the board they can go it should get me a couple of inches not sure on which enclosure yet
They’re discontinued Ill make sure they line up. this isn’t my first rodeo I grew up in Ventura ,ca all I did as a kid was bomb hills and street skate. Ive modified a lot of longboards. Im very aware that this is a different animal
Edit: I fat fingered the above paragraph had to fix the typos
guess Keda is 190kv right?..Good gear ratio, as you are big guy…you will have plenty of torque, but top-speed will suffer. In the future, you can tweak it to get a little bit more of the two worlds. For me, a fun board reaches 50km/h (31mph)…not that i always go that fast…but sometimes. I am also 165lbs, so i can always decrease torque to gain top speed.
Updated im tearing down my diyeboard . the xt connector melted together . also my diy eboard trucks broke when taking off the mounts they tapped holes for the grub screed and drilled through the hanger all the way to the axle. Im glad it didnt snap while i wss riding. So far today is full of suprises.
