I have ABS Enclosures for sale. I am a one man show. Not a business so, I would prefer to use Ebay if that’s alright.
Made in my shop from 1/8" Vacuum molded ABS sheet.
Middle will hold 2 up to 2 4s 10ah Lipo batteries (MultiStar High Capacity) or 2 6s 5ah Zippy Compacts. ESC area can fit the Castle XL2 or any other 1/8 or 1/5th scale car esc. I added an extra space in front of the batteries for other electronics (bec, on/off switch, charge ports, led…etc.)
Batteries and other mentioned electronics are not included.
This case comes trimmed. and ready to install. You can velcro it or fasten it to your board with t-nuts and screws (not included) If you fasten this enclosure with screws it will conform to the shape of your deck. Concave is not an issue. It is slightly flexible material so if your board is a little flexible it shouldn’t be a problem.
If you would like an enclosure made to your exact specifications let me know. I can make a mold for $80.
WELCOME TO THE EBOARD MARKET!
Thanks for posting your awesome creation! We 100% support DIY eboard innovations!
I moved this into its own topic/thread, because each new item for sale in the e-board market deserves its own thread so it can stand out & be found easily!
P.S. Its nice to have some other people posting here… it was a bit weird being the only person to be listing items for sale!
Got a model going today for the S.P.A.C.E. battery. Tried to add some concave to the mold. It may work better to just leave it flat…What do you guys think?
I’m really digging that strappy steampunkish design in the plastic. How wide is that compared to the SPACE cell? It looks like there’s plenty of room on either side of the pack if it was in the middle.
Can we see it cut and mounted? Man you’re really making me want to get some ABS sheets. Too bad a blew up my ESC this weekend or i’d get some and try this out finally.
Down the middle it is 430mm long x 153mm wide x 25mm depth
I put a wider deeper section at either end to maybe accomodate DD set ups or of course DR.
@Onloop because of my oven size I cant squeeze much more length- Please let me know if you don’t think these dimensions will work…
Those sections are 200mm wide x 31mm deep
This was just a run so I could see it. I’m going to make some adjustments.
@lhb I’ll get it cut and cleaned up, maybe mount it to a deck tonight. Thanks!
