Most likely not. I doubt the mounting holes are in the exact same spot. Might not be to hard to model it up though. All I need is cad/dimensions of the actual mount plate and I can edit the file to fit.
That pulley cover looks awesome! Let us know when you have it uploaded.
I have a 12s 6.6ah Chaka vesc 149kv 83mm setup and got over 12 miles with hills. You’re gonna love it
What’s the width of the belt. I am asking because I have a 12 mm width belt.
This is a 12mm belt.
Here’s the dimensions im using for my belt cover (torqueboards mount v4)
EDIT: The center to center distance i believe is 70mm, but i couldn’t measure it properly since my mount is in use. In practice, the 69.388 in that CAD doesn’t really change the taper angle too much to even notice.
Battery still running great!! I get anywhere from 8-10miles on the battery running it down to 25-30%. But I do weight over 200lbs.
Hey! Do you have an stl file? Thank you!
Uploaded the Pulley Cover to Thingiverse. Hopefully it works for you all. If not. I also included the Solidworks File so you guys can edit it.
Great!! Thanks a lot!!!
Ah guess it flexed enough when I installed it to not notice. I have updated the files though to have this hole spacing. .
Working on the Smaller VESC/ Switch enclosure for the board. 3D printed in ABS with the curve built in. Will use weather stripping and wood inserts to mount the enclosure. Current ones are a bit tight right now, so printing one that’s a bit bigger.
Debating on if I want to mount the LCD and the push button switch or just the Push Button.
Those enclosures look awesome! Would you be willing to share the .stl file for them?
I would also like the STL file
Posted the Case to Thingiverse. I sized it a bit larger than the photo before. This now fits two VESC or a VESC and an ON/OFF switch. http://www.thingiverse.com/thing:1817161
There is about 28mm between the bottom of the board and the inside top of the case. If people would like a “slim version” let me know and I can upload that. But I figured the slightly larger version would be a tad bit more universal.
I also have 1/4" thick weather stripping underneath to help make sure everything is snug and watertight. Adhesive side stuck to the board.
Maybe I missed it, but is there a matching battery case?
Not yet. I have one modeled to fit the MEB Battery which is actually quite a large pack. It however it JUST barely fits on my printer platform (Taz 5). Once I get a print and see everything works. I’ll post it. May have to split the part and glue it together. Which may be a safer bet printing wise too.
If theres a big request, and a bit of freetime to model. I may do a more Boosted Style one that fits a few Lipos or something.
