Got my Vedder Anti-Spark today and wanted to test it without plugging an esc on.
So i just connected a 20 V Power Supply to the IN-Connectors of the AS and my multimeter to the OUT-Connetors and measured exactly the 20V there. Fine.
But: The voltage is at the OUT-Connectors regardless if the Switch of the Anti-Spark is set to on or off?! Does anyone have an explanation for this behavior?
I remember something similar happend to me when i built this circuit. If i switched it of and measured voltage it was still high. But if i connect any kind of load (voltmeter already was enough) voltage drops slowly (depends on the load) to zero. Now with a esc connected there is a small load.
I assume its because the cap in the circuit must be discharged before it turns the mosfet off.
Of course Got a 12V power supply and a 470 ohms resistor. No need to use the skate voltages, i just want to confirm the theory with the cap that has to unload first.
