Can I use this 120A MAXI fuse on Vedder’s anti-spark switch 1.3?
As long you can connect the ends of the fuse to the spark switch you are fine. I doubt you will need a 120 amp fuse. I use a 50 amp fuse and have yet to break it.
what is the amp rating of the circuit?
