Hey forum! If you haven’t been able to tell im new to the electronic long board world! I just got a new job working for best-buy in my college hometown and need a form of transportation besides walking. The goal for this long board is to go 20+ mph and achieve 20+ miles! To commute to class-work-dorm. Im fairly tall and heavy. 6’2" and 230lbs Im trying to make this long board a plug and play so I will never have to worry about charging times, I can just plug it in before I go to bed and wake up with a full charge. I guess the best way to go about this is too add my parts list and just get extra verification that all the parts will work together and Ill achieve my goals! Please criticize my component list as im trying to make this long board last me all throughout college! Let me know if I should change and or add anything!
Parts list: Battery: https://hobbyking.com/en_us/multistar-high-capacity-6s-16000mah-multi-rotor-lipo-pack.html Motor: diy-electric-skateboard-kits-parts/motor-6374-190kv-3150w/ Pulley system: diy-electric-skateboard-kits-parts/36t-abec-drive-pulley-belt-combo-kit/ Motor Mount: diy-electric-skateboard-kits-parts/single-bolt-on-motor-mount-only/ Trucks, wheels & bearing combo: https://www.amazon.com/Longboard-Trucks-Flywheels-Owlsome-Bearings/dp/B01B08HCGK/ref=sr_1_15?ie=UTF8&qid=1478637783&sr=8-15&keywords=abec+wheels+longboard VESC: https://electric-skateboard.market/product/meb-vesc/ BMS: http://www.batterysupports.com/28v-29v-30v-60a-8x-36v-8s-lithium-ion-lipo-battery-bms-pcm-pcb-p-264.html Component Enclosure: https://electric-skateboard.market/product/carbon-fiber-battery-enclosure/ Long board Itself: https://www.amazon.com/Bamboo-pintail-Deck-Longboard-Skateboard/dp/B004URTVAE/ref=sr_1_1?ie=UTF8&qid=1478638264&sr=8-1&keywords=longboard+deck Battery charger: http://www.ebay.com/itm/Intelligent-Smart-33-6V-2A-Charger-for-8S-28-8V-29-6V-Li-ion-Li-Po-Battery-EU-/321471399664?hash=item4ad93046f0:g:YXAAAOSwKIpWBgVj On/off Toggle Switch: https://electric-skateboard.market/product/high-voltage-onoff-switch/ Receiver: https://electric-skateboard.market/product/2-4ghz-mini-remote-receiver/ Power Jack: https://www.amazon.com/Monoprice-Power-Pigtail-Female-Plug/dp/B004OCCARQ
My main concerns is connecting my battery to the BMS? Im still researching to try to figure out how this is possible. And then connecting my bms to the charge port! That and will this battery sufficiently provide enough range and power!! Sorry for the noobie-ness im trying to balance my research and classes together along with work. I just want to make sure everything is good before I bust out $800! Let me know what Yall think!!
