The cells alone would cost more than $80, these are either fakes or were bought cheap from boosted as ones with imperfections or faults
Yes it’s true but no one need a standard range battery now and it’s really hard to pull out the cells from the case. But with this information you may see people who use them for DIY.
Is it the middle data pin to ground or to positive for the BMS to output? Any idea if regen works?
The battery pack has arrived, and I am using the booted v2 original charger for charging, everything works fine.
No short circuit port, no output voltage at this time
Short-circuit port, output 42v voltage, but indicator light alarm
In fact, I believe that boosted will not let the defective battery leave the factory. The seller told me that it was detained at the customs.
Assemble the new battery to my boosted v2
Normal work, perfect!
Does your friend have more?
If he has more I would also be interrested.
Yes, he is still selling
Can you please link that?
I try to communicate with him, he will be selling in Taobao
My friend told me that if there are enough people to buy, he will consider accepting orders from abroad, otherwise he will only sell in China.
Maybe start a poll for who´s interrested
Is it possibe to buy two, rip out the bms, and put them in parralel with a bestech bms? Part of me wants one cause its $80, but then the other part is saying why? You could get more rangw with lipos for the same price right? Cause if you don’t use it with a boosted board you would have to use a different bms
Where can I order?
Well apparently op us saying you can enable the onboard BMS to output by shorting the middle data pin to ground. Not sure if he tested if it will actually output any current.
