so im trying to build a e board like the one @delta_19 did on his thread but i have 30 cells and building 10s3p… these are the parts im looking at to buy. i already have a long board (sector 9 42")
18650 3000mah battery (says original. 141USD with shipping to Canada for 30cells) https://goo.gl/z2KgDp
5.5x2.1 dc female
Charger
Power button
Battery Indicator. http://s.aliexpress.com/3mqAz2Mr
Bms (idk how to connect the battery indicator)
Xt90 Anti Spark
Motor
Vesc
Controller
83mmWheels
the tiny pulley (idk)
Battery box http://s.aliexpress.com/NfqM3qqQ
i) wheel pulley (option C)
ii) wheel pulley
questions:
which pulley is better (or works) with the wheels listed?
would it work if i used the battery box/holder to make a 10s3p? how would i do it? solder to one another? (i already planned out how to set it so it doesn’t fall so no worries there… and im planning to replace the tiny wires with 12awg copper wires to reinforce… if thats enough)
how would i connect the battery indicator? to what? vesc or bms?
does the bms work with this build? its 36v but IDK
what to do with the anti spark and power button?
your best 10s3p configurations for this build?
what are the best back lights, front lights you would recommend? how do you connect them?
