I am running a 10s 36-42V battery with a 3150W brushless motor controled by a 4.12 Vesc.
Everything is awesome from the board but it really cuts off when i go uphill for nearly 1km because of high temps. I was wondering if ventilantion in the case or lowering the amps could help… Any recommendations?
Right now i have motor max 60A
batt max 50A
Thank you guys!
What is max speed of your board? you might need to increase motor pulley to 40-46 teeth and make better cooling for vesc ( i simply drilled several holes around vesc. ). I have same single motor on 12s with same wheels, but i weight 75kg. if increase pulley is not an option, you need second motor to go long rides uphills
