Hello,
I am back to esk8 after a long brake. I still have two (collector) pieces : 4.7 VESC soldered by the master himself. I intend to use them with 9S battery and 190KV enertion 6355 motors.
I was wondering if I could upgrade them (beefing up some capacitors for example).
Does the BoM differ from VESC6? If not, then no need. Havnt been able to slay any of my hand soldered 6’s so far. I have some older PCBs before production, so I know there were some small alterations. Nothing major tho
I think you misread my post.
I have the 4.7 version. I know for sure that there have been BOM modification compared to V4.12 like capacitors. Also Chaka changed some components. I was looking for advice on useful and possible mods for V4.7.
Compared to VESC6, many things are different, you can hardly compare them in the context of V4.7 upgrade.
Ah, by master i thought you meant BV. The early test board of vesc6 was a v4 (or maybe 5.?)something.
I have some old 4.10-4.12 VESCs laying around. Theres one cap that is needs to be parallelled with the same value. (parallell on caps is same as plus), other then that I havnt modified them. They run ok in BLDC. FOC is bit riskier tho. Changed DRV few times.
OK thanks, I’ll dig in the forum archives to find which cap to solder in parallel.
I will surely not run them in FOC mode. For this, I’ll use a FOCBOX or a VESC6.
I blame BV tbh, he convinced me over and over that they “should” run fine in FOC. Depends a Little on what motor as well. SK3s are usually ok, but there are some motors which are prone to produce the DRV error more frequent. Impendance etc has to do with it.
