I am looking to build a dual motor atb and wire the maytech 8085 sensored to the vesc 6+. I don’t have the parts yet, so I can’t confirm but from pictures I can see that the maytech 8085 has a 6 pin sensor cable connector. Where the vesc is using a 7 pin connector according to Trampa. How can this work?
Probably my most visited page from TB:
https:///collections/electrical-connectors/products/vesc-sensor-wires
Or you can just solder the wires if you know the layout
How many pins does the vesc 6+ have? 6 or 7?
Here it looks like less of a problem as both ends have 6 pins. But Trampa says the vesc 6+ has a 7 pin connector.
http://www.trampaboards.com/vesc-6-plus-benjamin-vedder-electronic-speed-controller-p-26762.html
I tried digging but I have no idea.
Ok thank you!
Black, brown, white, green, blue, red. 6 wires
Hey Doneone,
did you already thought about the trucks and motor mounts?
Trucks going to be Trampa. Drive will be e-toxx gear drive
Did you buyed already your maytech 8085??
I am bit sad… i blowed up my aps 8085 (cleaned them with compressed air from the wrong side…)
So i wantet the maytech ones… and some 10 inch tires… but the maytech motors are barely half as big as the aps ones
So may i send them back or you can buy these new motors from me
