Not on the 4.7 VESCs since I drive them only with 7s and 10s with FOC. I had the breaking problem as well in 4.7, but it was related to BMS/battery cutting off (too high regen current if batteries are only capable of taking 1 or 2A charge current - changed cells!) and/or wrong settings in the min./max. current in BLDC tool.
I use a 4.7uf 16v capacitor instead of stacked 2.2uf caps. Stacking the caps puts too much leverage on the solder pads and could lead to them being ripped off. I have been using these: http://www.mouser.com/ProductDetail/TDK/C1608X5R1C475M080AC/?qs=sGAEpiMZZMukHu%2bjC5l7YegWuDAL%2b4n3PASDuuxtVww%3D
Mouser is out of stock on the TDX brand but you could use the equivalent from Murata : http://www.mouser.com/ProductDetail/Murata-Electronics/GRM188R61C475ME11D/?qs=sGAEpiMZZMukHu%2bjC5l7YbA1Uz8mFEbwIIDNOsfvAdY%3D
@FLATLINEcustoms Dang maybe this won’t solve any of my problems. It seems like it is worth a try though, and may improve performance since it is now implemented in the new HW.
@elkick If I apply this hardware update, could I encounter issues with uploading new firmware in the future? That is, are new versions of 4.7 firmware created anticipating that this additional cap is not there… I’d hate to fry my VESC in an effort to improve it!
No you wont have any issues with firmware. It only increases the capacitance making it more robust.
@dogeatgod @FLATLINEcustoms @elkick @chaka OK my cap for the C18 mod arrive. This thing is really small! Imagine taking a grain of rice and dividing it into 8 pieces… it looks like a tiny breadcrumb!
Time to get out the tweezer and magnifying glass. Any pro tips on adding something so small. I have a pretty good soldering kit with the pin-point tip.
I place about a 500 of those tiny little caps and resistors everyday! I use hot air but you can use an iron too. take your time and breath, but not too hard! Once you get the fresh cap in place you can hold it down rather than grasping with your tweezers and touch each end with your iron. There should be enough residual solder on the pads that it will flow with the aid of a little flux.
@treenutter any luck? I spent Saturday on some steep twistie mountain roads. Didn’t have the brake release once with reverse turned off.
@FLATLINEcustoms @elkick @dogeatgod @chaka I got the cap on there! It’s a little bit crooked, but I managed to make a connection on both sides. A few rides have proven successful! The only time I lose braking is if I’m on the board, not moving, and I apply full brake and move the deck forward and backward by shifting my bodyweight. After about six rocks the brakes release. But since that is a behavior that I never need to replicate in real riding, I think I’m good to go! I’m still curious about what causes the release, but I’m happy to be moving in FOC mode!
Sounds good. Did you cut those hall sensor pins where your cables are running across on the back side of your VESC? If not, you should do that. They can perforate the insulation of your red wire and full voltage will be applied to the v5 pin of the sensor port and that’s bad.
Mine just released again last night… ugh. No reverse still, maybe it was because I was full throw on the brake?
Bah - worrying.
Intermittent faults are the worse.
I’ve not had it occur since limiting trigger movement - fingers crossed it’s not just a matter of time…
I just posted up over on VESC forum. http://vedder.se/forums/viewtopic.php?f=7&t=222
It has to be the worst feeling on earth… not knowing when the brake is going to fail.
Could be that you are generating voltage spikes when full breaking on 12s exceeding the voltage limit of the VESC in certain parts of it. Just a guess, it didn’t happen to me yet.
I was riding with the battery around 44.2 volts but we have speculated that the regen maybe exceeding the max amperes. Just don’t know how to replicate it all the time. Just want it worked out. I like being able to stop when traveling around 36mph when I need to.
Did you try riding with 10s and see if it happens again? Of course please try it in a parking lot …with bushes at the end… For science and possible amusement
Did you try “current no reverse with brakes”? Also, try to lower batt min regen to -30, could also help preventing it.
I am on current no reverse with brakes I can try to turn down the min regen. What exactly does that control the minimum ammount of current that will regen? Wouldn’t I need to adjust max regen?
