In diode check mode, when you have a short it is suppose to show 000, but if you have over 150 it’s ok, that just mean that you don’t have a short over the Can Tranceiver U401… Now, if you can just check the continuity (for the black and the red wire) from your battery connector to the pads on the PCB, to see if you have a bad connection over the capacitor board. (because for what I’ve see from Torqueboards VESC the soldering on the capacitor board is not really good).
if i understood right here are the results. sorry but the host site has somehow flipped the view 180 degrees
It is ok to see some variation when the current is passing trough the capacitor. Buy from what a can see in your video I’am confident to tell your that you have a bad soldering over de ground wire… You will need to re-soldering it or contact @torqueboards to figure out orther option… Or I can do it for you but I’m located a bit far. (Canada)
thanks. i have a solder if its not something too too tricky. soldering from the side where it’s writted “vedder capacitor board” should do?
No, just resolder de power cable on capacitor board and test it again
did it, getting 00.2 on the read from the side of the output to the vesc
What is at 0.000 volt or on diode check?
the power cables (red and black) on the vesc
ok, so it is looking like a bad capacitor board, your best bet will be to contact @torqueboards to see if he can propose you any solution for the repair.
Hello, listgaus.
Did you fix that problem? I’ve also encountered it and I managed to find out how to fix it. I’m also from Israel so maybe we could talk.
