Hello there,
I’m trying to repair a broken VESC that got damaged probably because of a small short while riding (eventought there were 2 idenical oned connected to the same line and only one of them made it) I just had to replace two mosfets that were connected to one of the phases and replaced the DVR and boom it works after once of twice of just cleaning the DRV pins now the problem comes when trying to actually drive the motor the motor makes a single step and then kinda gets into fault mode with these results after trying to run a motor detection:
The following faults were registered since start:
Fault : FAULT_CODE_ABS_OVER_CURRENT
Current : 147.2
Current filtered : 145.1
Voltage : 31.18
Duty : 0.643
RPM : 181.5
Tacho : 7
Cycles running : 2528
TIM duty : 4031
TIM val samp : 2015
TIM current samp : 5149
TIM top : 6267
Comm step : 3
Temperature : 43.77
Current : 143.5
Current filtered : 144.7
Voltage : 31.15
Duty : 0.651
RPM : 52.8
Tacho : 13
Cycles running : 5824
TIM duty : 4037
TIM val samp : 2018
TIM current samp : 5121
TIM top : 6205
Comm step : 3
Temperature : 44.22
Current : 145.1
Current filtered : 145.3
Voltage : 31.06
Duty : 0.680
RPM : 157.5
Tacho : 23
Cycles running : 5817
TIM duty : 4056
TIM val samp : 2028
TIM current samp : 5012
TIM top : 5968
Comm step : 3
Temperature : 41.11
Current : 146.5
Current filtered : 144.6
Voltage : 31.32
Duty : 0.685
RPM : 52.9
Tacho : 29
Cycles running : 5613
TIM duty : 4059
TIM val samp : 2029
TIM current samp : 4994
TIM top : 5929
Comm step : 3
Temperature : 44.12
any clue to what could cause that? something to replace?
Thanks for helping!
