Does anyone have some decent configurations for a 260kv motor. Want to go about 25 at max speed.
I use Multistar Batteries and I have it in Series, 6s would it change the config at all
It would change the Batt Max + Min and the Battery cutoff start + end. But there was an issue using 260 kv with 6s battery. I dont know exactly what is was, but maybe you can find it here:
what would you change it to.
What is the c-rating of your battery?
I thinks it’s 10c, how can you find out for sure
its for sure a 10c
Got any Configurations?
10c = 10 x capacity
so if it’s a 5,000mah battery, 10 x 5,000 = 50,000mah or 50amps.
So set battery max to 50A in that example above.
My suggestions:
motor max 70A Motor Min -50A (adjust this if braking is too weak or hard)
Battery Max 50A (10c, 50A based on the example above - adjust for your actual battery capacity) Battery Min -10A (2c, -10A based on the example above - adjust for your actual battery capacity)
Min Volt: 8v Max Volt: 30v Bat Cutoff Start: 20.4v Bat Cutoff End: 19.8v
Sweet that’s what i’ll try and find out if it works. Thanks man.
Sorry I have 2 3s batteries that are multistar. Would that change the config at all or would it stay the same as above.
If you are running 2 3s batteries in series then the above settings will work. It’s setup for 6s (2x3s).
nice new to this Thanks
