Do this Download and Extract: https://drive.google.com/file/d/1ei5p-xRrJsaJiyP6jYGHhD0cMyFX8eqF/view?usp=sharing 2: Right click on the unknown Device and select properties 3: Select driver tab 4: Click update driver 5: Choose the directory where you extracted the above file 6: Let the Window install the driver 7: restart your PC and VESC 8: Then check if STElectronics COM port appears under Posts (COM & LPT)
i clicked on the adress and this has come up
Click the down arrow on the upper right corner of the screen to download these files and then follow the instructions
i downloaded it but i think it is ziped and it cant be open
You have to unzip to a desktop or something first (Use Extract Command)
i will do it
i unziped them but still not connected. the error is code29 of usb. i dont know what is code29. doesnot need any serial number of vesc/?
Download and install team viewer and let me know your ID and Password, I will solve it for you
i installed it.i will tell you the exact time of connecting to team viewer bro.
