Current No Reverse With Brake mapped, center set, but when I accelerate there is no relationship between how much I move my acceleration and how fast motors are going. And motors starts to spin to 100% on 15% from controller. I tried so much settings with Pulselenghtand anything changes it even a bit
On Duty Cycle its working well but I got other problems on this control type so I want to stick to Current control.
Can you help me ?
I think the nanox works better with the Standard r2 Firmware.
When i used it with acks Firmware i fine tuned the throttle curve a lot to decrease the Power on Low speed.
Btw i like Index Finger Controll more because the throttle way is longer and thus preciser
Bench test, but on duty cycle there was no rapid acceleration
Now I a little bit scared to test in with load because I do not want to my board fly off.
If youāve tried to tune it to work on a bench test it wonāt work well under load. Make sure the full stroke is mapped to the vesc.
EDIT:
My bad, just connect the belt and it will work fine. I couldnāt see that it wasnāt on viewing on my phone.
Itās working exactly as it should. Current mode is more like the throttle in your car. If you give your engine 15% throttle in neutral itāll rev high, but under load it wonāt.
There is absolutely nothing wrong here, just a lack of understanding.
You are correct, but thatās not the problem here. 15% throttle will net 15% speed only if in duty cycle mode. Current mode behaves very differently. It is doing exactly what it should.
If you look at his screen shot you will see that he has 14% throttle but 95% duty cycle. This is because of current mode. NOTHING IS WRONG.
I dont think that you need to calibrate the remote in every ride. You can turn the Board on and then the remote. This way you dont need a recalibrate and you will use the old settings
Correct me if i am wrong
For other remotes maybe (havenāt tried) but itās known for the nano X in particular you do have to do this ācalibrationā routine full throttle and full brake before connecting to the vesc to have proper functionality when the board is turned on.
Otherwise your initial 15% throttle will = 100% throttleā¦ Which is very jarring. Another option if you turn your board on first is to still just go full throttle full brakeā¦ Just spinning your wheels insteadā¦ Your remote will work properly after thisā¦ With a nano X just donāt not calibrate your remote and hop on straight away or your throttle and brake will be hyper sensitive until you use full range of motion at least once.
Still, seems this may not be OPs issue, Iām leaning to agree with @AutoItKingās assessment of the situationā¦ No load is very different than load. Just properly map your pulsewidths minimum, center and maximum values in vesc tool to = -100% / ~-0.5 - 0.5% / 100% output from ESC respectively, calibrate your nano-X full throttle and brake, turn on board and test with a load. Should be fine.
