I was riding at the beach, everything was working fine. I then charged my batteries two days later, switched on my board but nothing happened after pushing the remote control.
I can communicate with the VESC normally using the BLDC tool but as soon as I run the motor detection the motor doesn’t spin and I get a bad detection result (the same motor works properly with my other VESC).
So, any ideas (beside the obvious one of buying a new VESC )?
No official release. They put Benjamin’s name on and vedder.se, or didn’t remove the branding from the PCB files that Benjamin Vedder published years back. It is an old 4.12 design.
Install VESC-Tool, update the FW. Select the FW 4.10,4.11,4.12
Try to run motor detection., If that does not work, get a new device.
If you use CAN BUS on a V4.12, be sure to always switch them on simultaneous (e.g. connect them to a single battery/switch). If you switch them on one after another the CAN transceiver will blow up.
