Hi guys, this my firs post here, iI hope I don’t get a ban!
Maybe somebody can explain me what happened to my VESC . Today I rode my DIY board. It was all OK until I got off the curb. One of the two motors began to slow down when I pressed “forward” on my RC. Second motors was pushing me forward, I mean that one is strongly hindered and the second was gaining speed, not the most pleasant feeling… Sometimes it started working properly, but then this problem appeared again. Later I removed the belt because I couldn’t remove the cover and disconnect it. For a while It was rotated properly, then again disconnected. Then completely ceased to rotate the motor. At home, it absolutely stopped responding to RC. Recently I had the same problem, I reconnected VESC and everything became all good, corrected wires and everything worked. As a result, I can connect this VESC to the computer, I can update firmware without problems, it reacts to RC ( LEDs indicate this), but the engine does not rotate. I made a video of how I connected it to the VESC Tool. Here you can see how VESC “works”… Can you tell me the reason? VESC DEAD??
It’s possible, because the first time I ran into one, I was just fixing the wires, and at some point, things got good. But now he does not react. And it scares me too much of the current spread on the lower scale.
