@JohnnyMeduse hopefully you know, whats the part # for this diode(D4), my fume extractor ate it while I was moving it out of the way to replace all the caps lol
Itās a Shottky 60V 2A 771-PMEG6020ER-115 (parts number on mouser)
Awesome thanks
While Iām ordering parts is there anything I should/could upgrade?
Hello,
I have purchased one enertion vesc controller 4.12 version and after setup with 2 lipos 24V, motor has worked one or two spins and then fault DRV8302 has appeard in the pc tool. Temperature of the Mosfet is 29 degrees and the range of voltage is fine too. Can you help me if Iām missing anything important?
If Iām not mistakenā¦these are the ollin ESC upgrades for reliability. Iām sure you can find this info on vedders forumā¦
C1,C8,C9,C39,C40,C43,C44,C49 10uF 50V replaced with 4.7uF 100V
C37,C51 15uF 100v replaced with 22uF 100v
C24,C10,C11,C12,C13,C14,C16,C17,C18,C20,C23,C26,C31,C35,C41,C52,C401 2.2uF 16v replaced with 4.7uf 16v
Yep got all those, went for the high temp tolerant versions too, donāt know if itāll help but it canāt hurt
I fried both my VESCs while testing out FOC on my mountainboard. Anybody in San Diego willing to help repair them? If not, what re my options?
You can do it yourself too. Drv chips are about $6, order 3 or four and have it. A hot air reflow station is $50 ish on eBay and will serve you useful in many other hobbies. Iāve never soldered till I replaced my drv and it wasnāt horrible
finally someone knowing Louis on forum just watching his videos would give soldering practice
Around 240Cā¦ but if it is lead free it could take up to two minutes to really liquify the tin, using small circle around the chip.
Please let me know if you are still willing to do this! I have a bad DRV8302 chip in my brand new torque boards VESC (firm 4.18). I am heading up to LA and would gladly be willing to drop it off along with double what you quoted! Sorry if this isnāt a PM, I signed up for the first time after being a long time lurker just to message you. The VESC still operates for the most part.
what temp did you use?
Around 240deg Celsius
I was hoping not to have to visit the DRV8302 failure threads but here I am.
Pair of new VESCs from @Karen_Vanda had them in a box since delivered and just tried to power them up together (over can and powered at same time)
Only one motor spins, the other gives the DRV error fault So seems like Iāve had success replacing the thermocouple chip on my 3d printer just now & I want to jump straight to the advanced lessons of esk8 soldering.
Tools Hakko with which Iāve become very attached to A butane powered soldering torch Iroda Solderpro 120, which could be used as a heat gun since it has a torch tip Infrared thermometer with location laser Amtech flux RMA-223 Cored solder
Would it be a lot easier to use the torch and get some solder paste?
Iāve seen a couple of vids and this one seemed to meet success even though to me looks done ham-fistedly Pros and cons of each method? Do I need solder paste? I have zero smd soldering experience
Take the plastic off by pulling it over the pins before soldering
that would be the next one, Iāll get there thanks for the advice
