So I used my VESC from enertion for about 2 weeks in FOC mode. Then today on a small ride suddenly my brakes did not work anymore. I stopped looked at the VESC but everything seemed to be fine so I drove on. After about 2 km it happend again, once I got home I connected the VESC to BLDC-Tool and got the following output upon typing faults:
Fault : FAULT_CODE_DRV8302 Current : 0.3 Current filtered : 0.0 Voltage : 39.40 Duty : 0.00 RPM : 109.1 Tacho : 1897215 Cycles running : 1 TIM duty : 26 TIM val samp : 5 TIM current samp : 8398 TIM top : 8400 Comm step : 0 Temperature : 41.11
Fault : FAULT_CODE_DRV8302 Current : 0.1 Current filtered : -0.0 Voltage : 39.12 Duty : 0.09 RPM : 5968.7 Tacho : 2464606 Cycles running : 2 TIM duty : 763 TIM val samp : 5 TIM current samp : 8398 TIM top : 8400 Comm step : 0 Temperature : 71.95
Fault : FAULT_CODE_DRV8302 Current : -2.5 Current filtered : -0.3 Voltage : 39.09 Duty : 0.00 RPM : 73.9 Tacho : 2608636 Cycles running : 1 TIM duty : 35 TIM val samp : 5 TIM current samp : 8398 TIM top : 8400 Comm step : 0 Temperature : 74.21
After l hooked everything up on my bench, sometimes when i press the throttle it starts spinning sometimes it does not and delivers a drv fault. The rate is about 50% to 50 %, but when it starts spinning it wont stop. Is there a chance of a bad solder joint which causes this problem ?
Compared to my roommates VESC who is using BLDC mode my VESC with FOC gets much hotter
