Per request (@Michaelinvegas) I decided to share my VESC enclosure design.
The main purpose for this:
Protect the VESC from physical interaction with other components in our (often) tight eboard enclosures. Avoiding damage to the VESC.
Clamp the soldered motor and battery wires to relieve any stress from the motor wires. I for example had the motorwires move alot when turning the board, thus tugging on the wires.
Give me your thoughts on the design and any new features that would be handy to implement. I’ve tried making it as low profile as I can. I will add some velcro to keep the VESC from rattling inside
INNER DIMENSIONS (3mm plexi):
W= 44mm
H= 21mm (I can decrease it by 3-4mm, but as every VESC is shrinkwrapped a bit differently I thought I’d leave some room)
L= 138mm
If enough people are interested I will maybe sell them. I have to wait for an hour or 2 to use the lasercutter and I can get about 2.5 enclosures out of a (€7) plexiglass sheet. So I think a price of 5-10 excluding shipping is what I was thinking about, but those are details for later if there is interest (and for which pricerange). I can also make it in different colors
Yeah sure I can just double the width and add a seperation plane (or any other suggestions). But I wanna make sure it fits, so I’d like to ship the first one to someone with 2 VESCs (because I don’t have 2) and I wanna be sure things fit before more people want to buy one.
Sure I’ll do that this evening. The dimension should work for normal VESCs, but as I said: if your VESC is wrapped a bit different then the fit might be a bit off.And keep in mind: the slots are for 3mm thick material.
Thanks! Yeah I’ve thought about it, but the plexi is 6mm in total and with 12mm left that won’t be enough I’m afraid, there certainly isn’t a cm left in there to take away I’m afraid. But if a slimmer version is preferred I can still shave it down to 18mm inner diameter
@3sly That looks really nice. I’ve always wondered why nobody had come up with a case design for VESC’s. They always looked so fragile and exposed to me, even with the shrink wrap. When I do end up getting one or two, I’m definitely gonna be looking for this case for them
LMK, I have a few builds underway I could use this with, double ESC. Will check out thingverse, but I have only used that for 3D printed wheel pulleys and don’t have access to a lasercutter (or even where to ask for that, out of my comfort zone!). Any pointers on how to get one made, I am in NYC. Thanks for any advice on this!
Ow yeah seems like it wasn’t posted do to my account created earlier. Now it’s online.
Yeah it’s only makeable with a lasercutter, I used a trotec lasercutter in the Fablab. Do you have something similar in NYC? something like this makerspace: http://www.meetup.com/fat-cat-fab-lab/
For me it’s free to use, just takes a while to wait for one to get free.
A note on the design though: I’m gonna change the ventilation, because do to the heat the acrilyc bars bend a little.
