Im in the process of building my first electrc skateboard so I am new to this. Everything was working perfectly until I brought the board outdoors for the first test when the motor just would not spin. I took it back inside and the vesc gave me fault code ABS_OVER_CURRENT and i could not get it to work, even after tweaking the current settings (Running in FOC btw). After letting the board sit over night I tried to re-configure the motor and it works perfectly again for a couple of minutes and then the motor stops spinning and i get the same fault code again.
This is the latest fault code I got and here are my settings:
Currently i get the fault code while trying to measure the flux linkage, that is why it is set to 100,000 mWb.
I still have the same current settings. The motor twitches once and then the vesc blinks red, nothing happens for a couple of seconds then the motor freaks out.
Set absolute max current on 120A and you are ready to go. I had 90A on my focbox and also had over current. After I switched it to 120A (default setting) the fault was gone.
And also, according to the real time data, the vesc (or motor?) is drawing ~0.1A while not doing anything… Is that normal? Since i dont remember it doing that in the beginning?
I would first check my connections.
Abs overcurrent can come from a bad solder join or one of your plugs or bullet connectors not 100% plugged in.
Also check the pcb of your vesc.
Can you se find some lose connections?
Have a special eye on the legs of the capacitors. If there is something lose, broke it might be the reason.
Unplug both of the motors if dual setup
Swap them, plug them back, make sure joints and connectors are properly connected
Set the values to lower, your ESK calculator for that
Perform detections, and throttle check then
ABS_Overcurrent occurs when one or more motors are faulty or values are not accurate for the setup.
Did you have any luck solving this @affeandersson? My VESC has the exact same problem: applying any throttle results in the motor stuttering once or twice, then the red LED blinks and a FAULT_CODE_ABS_OVER_CURRENT is logged. Motor detection also fails. I’ve tried a few different motors with the same result.
