This video is not for those without basic knowledge of coding. if you can not do this your self but need to then please let me know and i can do it for you.
I go through the steps to modify the default motor and application configuration setting in the firmware and show you how to make configuration files that you can use as defaults when ever you are updating your firmware so that you can save time on configuring your vesc agin after firmware updates.
i also show you how to make modifications to the baud rate of bloc tool.
the process isn’t complicated but if you get it wrong you can mess up your vesc.
i demonstrate how i have configured default setting for enertion raptor electric skateboards
