Hey I am trying to update my maytech vesc(3.56, vesc tool refuse to work with it till I update it). It tells that the supported firmware is 3.57. Can’t find that firmware anywhere. Where can I find it?
Thanks in advance; Ron
You do not need to look for files. The vesc tool will find them.
When I do that it like fails to update it and and the vesc stays at 3.56… What is the problem? Maytech vesc 50a
that is the error I get: Serial port error: The I/O operation has been aborted because of either a thread exit or an application request
Did you wait at least ten seconds after firmware download? If you did and the firmware is not upgrading you have the same problem I had not so long ago. Only st-link can solve it in that case. Do you know how to flash it? If you do not know there’s a few threads about it.
This is how mine looks:
useful links:
https://fishpepper.de/2017/10/31/tutorial-initial-flashing-a-new-born-vesc/
http://fishpepper.de/wp-content/uploads/2017/09/VESC_FW_AND_BL_092017.zip
I will check this out. Thanks a lot!
