so I got a problem, my board sometimes goes all out of knowwhere 100% on the brakes. this usually happens in intersections. when approaching the intersection I let smootly go the throttle, most of the times halfway past the intersection I (super carefully) go back on throttle. and then shit happens, sometimes with the absolute over current faultcode.
I already did a few motor detections.
some build info:
190 KV motor
vesc 4.10 running ackmaniac
In most cases, I would suspect interference in your remote signal. Try changing channels at the mentioned intersection and see if it gets better. Try holding it close to the board.
Edit: The interference coming from ground loops magnetic fields, Radars watching traffic or even wifi when it’s very modern
Yeah, I’m Belgian, so if you’re not to far away and want to get to the bottom of this, we could figure something out. Got some winnings laying around
Not sure if you know this or it helps but you have to recalibrate the remote everytime you turn the board on. One flick up and down and you’re good to go.
just to close the topic, the problem was an external motorwire short. The wire protection was rubbed off the cables partially and therefore two wires were able to short.
