VESC - Hard Brake error
Hello everyone. I have been lurking here for a while but cant seems to find anything fully related to my problem.
Setup:
  • Space Cell
  • 2 R-spec Motors
  • 2 VESC (Updated to 2.15)
I have tweaked all the settings to the VESC per data from this forum. Currently running in CANBUS. PPM mode, current no reverse with brake
Problem: When I go from full throttle to full hard brake, the motors will cut out and only the (slave) VESC will have a blinking red light. If I wait a few seconds for everything to settle, I can throttle again with no issue. Slow braking does not cause an issue.
What can I do to stop this?
what regen settings do you have>?
for battery & also motors?
I am following this link
For each VESC: Motor Max: 80A Motor min (regen): -60A Batt Max: 15A Batt Min (regen): -12A
try lowering the settings
Motor Max: 60A (or 40A) Motor Min (regen): -20
eh. not working. now it seems to cause so intermittant issues with throttling back up. starts cogging (i think is the term) when throttling back up.
disabled CANBUS and I dont have the problem with single motor/vesc settings. guessing i am tripping some current limit…
Did you run the motor detection after updating firmware?
old thread i know…
im having the same issue, did you ever find a solution?
Post Screenshots of your general motor and advance motor settings.
I am having this issue with dual carvon’s/ space cell 4… Settings are as follows:
motor max: 30a Motor min: -30 bat max: 20a batt min: -8a abs max: 65a
I have one board with these settings and 97mm wheels that works fine, this board has 90mm wheels. Anyone think the wheel size could make a difference? Anyone have any suggestions?
Raise your absolute max current to 120-130A
These are settings for a dual vesc…
Ok, raise your absolute current max on each vesc to 120-130A.
If you have this value to low the vesc will shutdown on a current spike and risk street your face
Oh, ok, I thought all the numbers where supposed to be divided in half?
Not the absolute max, it’s a safety mechanism for the vesc and it’s sensitive to current spikes (will shutdown the vesc once it hits that value)
But if you are having a shutdown issue apon braking, is your max input voltage set at 57V?
57v yep…
I wonder if the smaller wheels generate more amps? The 97mm board has the same settings and does not have the hard brake error…
Are you using FOC or BLDC?
I thought I already mentioned that they should be higher :stuck_out_tongue: Did you check for faults like I mentioned?
I am using FOC… Does anyone really use BLDC??? Can’t really check for faults because the vesc’s only cut out for a second, they are fine by the time I get home…
I’d say most people use BLDC, myself included. I’ll never use FOC until the VESC 6 as I’m not comfortable risking a $170 speed controller and potentially my life since I live in a place with a lot of hills.
Why can’t you check for faults? When they cut out they might be generating a fault. Just go home, plug it in, check for faults in BLDC tool. Just make sure you don’t turn it off in the time between.
