Hey everyone, I just put my first build together and I had it working for only a moment… So basically my problem I believe is the DRV or the motor…
My build: -Turnigy Aerodrive SK3 - 6374-192kv Brushless Outrunner Motor -2 Turnigy 5000mAh 5S 30C Lipo Packs in series -VESC 4.12 from Miami Electric Boards
I’m using firmware 2.18. When I first hooked everything up it worked like a dream. Motor detected, controller operated it, could go forward and brake etc. This was before the wires were secure so I hiked them up for a test run, and then when I was actually ready to hop on and test it I got nothing…
Hooked it back up to the computer and couldn’t get the motor to spin once so ever. Not with the transmitter, the computer, nor the motor detection. After running the motor detection and looking to the terminal for faults I get this:
Fault : FAULT_CODE_DRV8302 Current : -1.2 Current filtered : 0.4 Voltage : 41.35 Duty : 0.01 RPM : 0.3 Tacho : 3 Cycles running : 3 TIM duty : 689 TIM val samp : 356 TIM current samp : 24112 TIM top : 47511 Comm step : 3 Temperature : 25.42
Fault : FAULT_CODE_DRV8302 Current : -0.3 Current filtered : 0.6 Voltage : 41.35 Duty : 0.02 RPM : 0.3 Tacho : 4 Cycles running : 3 TIM duty : 991 TIM val samp : 523 TIM current samp : 22415 TIM top : 43784 Comm step : 4 Temperature : 25.49
Fault : FAULT_CODE_DRV8302 Current : 0.9 Current filtered : -0.4 Voltage : 41.29 Duty : 0.02 RPM : 1.2 Tacho : 5 Cycles running : 4 TIM duty : 991 TIM val samp : 523 TIM current samp : 22415 TIM top : 43784 Comm step : 5 Temperature : 25.52
What should I do here? Can I fix this? Please, I was so excited to have this thing working and right on the brink it seems to have failed…
