I recently installed my VESC and when I try to push to start it, it does these short quick brakes until I stop pressing the trigger. If I press the throttle before I start then it works just fine. Has anyone else had this problem? Thanks!
What’s your setup? and what VESC are you using?
I have the space cell pro 4 , enertion esc and a turnigy motor
You probably have the brake parameters setup so zero throttle (or 50% depending on your controller) is brake, when that should be coast (no brake). It should only be braking below 0 or 50%.
This should help you…
http://www.electric-skateboard.builders/t/vesc-faq-setting-up-receiver-and-brakes/244
