it improves the connection and has one very cool new feature. You are now able to connect to Ackmaniac-Tool or VESC-Tool via the app.
To do so you need to press the question mark sign on top and then in the menu the entry “Start TCP Connection”
If it doesn’t work at all then please stop and restart the Wifi connection of your phone. Of course your Smartphone and PC need to be in the same network for this.
If you are outside and have your Laptop then you can activate a Hotspot on your Phone and connect to the Hotspot with your Laptop.
Hope it works for everybody.
Donations are always welcome and will be invested directly in which i had a lot in the last days for the new firmware and app version.
That’s awesome, so I guess in order to be able to work wireless with both of the vesc we would need to bluetooth modules connected to the vescs. Is it correct? Anyhow I can connect via TCP. Thx
Sorry I didn’t explain properly. I know I can change the motor battery setting through the app and via CAN be transfered to the slave VESC. My question was about firmware update. Is it possible to update the firmware om the VESC via TCP? Do O need 2 bluetooth modules km that case? Thx
Anything that is limited on the Ack-tool when connecting to the app via TCP? For instance, would motor detection work?
When reading real time data in the tool via app it looks like the ack-tool looses connection/read once every few seconds, so it doesn’t run very smooth. Is this just how it is when running though TCP ?
No firmware updates won’t work. Over Bluetooth it happens that packages get lost. And for a firmware update it needs to deliver like 20000 packets. So that won’t work. But motor detection, and read and write of settings works.
Yes the connection isn’t as stable as with USB. Best is to place the phone and Laptop close to your WIFI Router and the board close to the Phone. Also be aware that the reliability of your Bluetooth connection can be very different in portrait (vertical) and Landscape (horizontal) position.
And if you want a faster connection you could increase the baud rate of your Bluetooth module via AT commands.
And Heart Beat (Heart sign) should best be deactivated because it occupies the connection a lot.
Samples will also not work. Just simply see it as a possibility to read and modify your settings without taking the enclosure off.
I’ve been writing a couple of times about not getting KV reads in the terminal of the Ackmaniac-tool, so as the feature was implemented with the app I thought I’d try it, but unfortunately with the same disappointing results =
it just says measured kv: 0.00 rpm/v. ERPM reads are fine when checking for that, but not kv.
I’ve tried this on both motors (running dual focboxes).
Because the motors need to spin to detect the kv. So just speed them up, release the throttle and immediately enter the kv command while they still spin.
the value you will see then needs to be devided by (number of magnets/2).
So when you get 1330 then devide it by (14/2). 1330 / 7 = 190
If you have a 6374 190kv motor then don’t be surprised when you get a value in the 170kv range.
I tested on different PC, but basically I can connect easy via TCP but I can not read the configurations present on the VESC both motor and app. Do you have any idea why?
So I tried with another pc and this time it worked. Perfect. I see the parameters but if I try to change them and click write the motor configuration it doesnt do anything and if I check again it still have the old value.
Second thing I tried the KV detection. I get 634 rmp/volt and my hubs have 20 magnets so I get 15 KV when should be around 75. Did I do something wrong? Thx
Its magnets / 2. So 634 / (20/2) = 634 / 10 = 63,4
And with the write i also saw the the green Text at the bottom right doesn’t appear with the write. But in my case the write worked. Just change a value, press write maybe multiple times and then read to see if it changed the values.
Think i know why it doesn’t appear but don’t have the time right now to spent time on it. So maybe in the next days.
Update: With me it does,t work. App vers 1.98 I can connect to pc via TCP but I only get the green text for connection but not the ones that tell about read motor and app conf. Indeed I do not see the value present on the VESC anymore. Moreover after 3 minutes connected the app crashes.
May I ask you something. I have dual hubs motor, 10s3p 30Q battery and I set a max watt of 1950 watt (9752) with batt max 30A, motor max 50A motor min -45 and att min -6. Now my question is why I always see in the telemetry chart that for instance I get 1400 watt (7002) out of it? the batt current never go more than 40A (I guess is times 2 in the app so 20A per VESC) and motor current reaches 45A (so 2.25A per VESC). MAybe it is just the physical system limit for my motor and battery. I just would like to ask you your opinion. Thx
Tiny little suggestion on the android app
When changing the screen resolution, the infoboxes won’t follow. Would be nice to have them staying full screen all the time or adjustable in options.
