Check for loose wire.
Hmm. Hadn’t thought of that. I will when I get back home
dont get discouraged with a single drive! I ride a balance-discharge 10s 149kv single drive with an Ollin Vesc for 3 years now and take it up and down steep hills daily without problem. Only “issue” I have is a mental thing where I’m used to releasing the trigger when I’m coasting, and I sometimes accidentally do this when going down hills otherwise I’ve had no issues except for when the wheel cant grip the ground
Check the caps are connected properly. Might have broken from vibration.
@Ackmaniac was right. Soldered the hell out of multiple leads, checked everything, all is well again. Thanks everyone!
I definitely have love for single drives! I just love duals too sounds like a great setup!
Battery Current 90A is too much, also motor current is a tad much. Focbox and others like it can take 50a continuous but to be safe i wouldn’t set it higher than 40a, but thats my opinion. But 90a is something i haven’t seen so far, except normal esc
I’m having this problem, which wires should I check. All the wires on my vesc appear fine
