ok, cut off the heatshrink drv is fine, solder joints ok. looked on the back and mmm that empty spot looks weird? check other vesc oh there should be a cap there.
check back at heatshrink, cap falls out!
now whats the value on this thing? can I solder without how air? pads are pretty big but still…
its the size, actually i’m lucky it this huge cap. with huge pads.
its the angle! pins on the side and leds on the other. I have rosin core solder, but no flux.
been looking for an excuse to go back to this spot anyways. they also have cnc mill, huge xcarve, 10x 3d printers. including a huge stratisys and form2.
Wow! That sounds like a DIYers dream! I have soldered many of those caps on VESC’s. You just need a steady hand and a pointy soldering iron tip. You probably want to get a new cap as the metal tabs on the sides may be damaged or gone. I may have some extras I can send you, if needed.
