Torqueboard vesc, from diyelectricskateboard
yeah that is it
To me it sounds you have a small manufacturing issue, the temperature sensor is R1, but that doesnt mean the issue is there
Im still getting this issue
so i should get a new vesc?
Ya something is up with your temperature reading⦠your at 100degC, stuff would start to burn. Take this up w diyelectricskateboard
98% sure this is a manufacturing defect, no bad settings would cause this to happen
there isnāt any setting that can be changed to fix this?
okay thanks guys. This is just so frustrating as ive waited 4moths
Could offset the mosfet temperature start & end by 70 degrees⦠but thatās the bowboy way of doing it
what would the exact numbers be?
Well i dont recommend doing it, but mosfet start 150 end 170
I mean if itās already broken why not
Because youāre covered from a manufacturing defect?
ohh okay. What is wrong with setting the temp higher?
Well you would be shutting off the temperature protection⦠and im not entirely sure that the reading is good or not
Maybe one of your mosfets is actually shorted out and is getting hot
Hard for me to tell, thereās a forum in the way
Well i just rode it and it works totally fine now
Keep in mind thats a cowboy fix, could lead to permanent damage if thereās an actual temperature issue
and youāre welcome
thank you very much
