Most of the VESC’s that I have found online in the $50 to $75 price range seem to be rated for only 50A. Specifically, the VESC that I was looking into: The Flipsky Mini FSESC4.20 which is rated at 50A.
The motor that I had picked out for my esk8 design was a 190 KV motor from Maytech and it has a rating for 60 A.
Will these work together? If not, what VESC do you guys recommend with this motor or a similarly spec’d one from maytech?
Finally, how do I spec the battery with this? I followed this guide and I want to make sure that I have it right. My goal is a dual motor set-up with each motor being the ones that I liked above, each is rated to have a max draw of 65A. That means I need the battery to be able to supply 130A (65A * 2) and I need a battery that can supply at least 130A. Based on all of this, I believe that I can use 6S LiPo batteries correct? Is there any benefit in using 10S batteries or 12S batteries for my build? I do realize that mroe voltage means less current, so therefore less heat, would that be a good reason to spring for a higher voltage battery?
Can anyone point me to a place where I can find some 10S or 12S battery packs, I don’t really see many options online that are reasonable?
