So I rebuilt the Old Man Cruiser over the winter. Same hardware, new form-factor:
Single Turnigy 260kV 8S1P- Zippy Lipo 4s1P 8000mAh (x2) (30A inline fuse) DIY Electric Skateboards power switch Enertion VESC 4.12 Torque Boards 2.4Ghz mini remote
During testing, I fried the VESC (shorted something). The batteries on the fuse were fine. Appears I burned the dreaded DRV8302. I was able to read the VESC firmware so I saved off the configuration. I bought a replacement through DIY Electric Skateboards. After getting it in, I configured and found everything ‘squishy’. Torque was low, brakes less, top-speed reduced…
I went back to my build thread and pulled my VESC settings from there. ( here: https://www.electric-skateboard.builders/t/old-man-cruiser-new-re-build/7806) No difference. Hmmm. I did my maiden long ride this morning into work. It is about ~11 miles at around 57F. I was barely moving by the end and had to kick in a few places. My top-speed was low, the board was measured at 27mph last September; I may have hit 15mph this morning. The first battery is now connected to the charger. The cells showed voltages: 3.83, 3.83, 3.82, and 3.72. These look right to me. Won’t know mAh charge until later…
What do you think? I’m thinking my LiPo’s purchased in Augut last year are already toast unless I’m missing a configuration item in BLDC Tool.
and re-applied firmware settings for the motor and batteries, re-set up the remote controller, and went to test.
