So this will hopefully not be another “how i burned my vesc” thread.
But i wired up my new setup and and everthing themed to work fine, i connected it and updated the firmware, used very moderate settings
Motor current Max 25A
Max Brake -25A
Battery current max 25 A
max regen 2,5A
V shutoff at around 20,4V
until the Vesc Tool wanted to detect my motor and after the first beep it shut off all of the sudden.
Now the Vesc shows the blue light for a second when i turn it on and then shuts off.
this is my wiring diagramm: (ofc there are 3 motor wires)
To give you some background this is my old setup where i added a esk8.de Vesc with an anti spark switch.
I also changed the old battery setup to a spot weldet one, same batteries tho, still 6s samsung 30q´s.
No, you are Kinda right. I had to customize my motormount, which was´nt fun because i don´t have prober tools for this kind of work and use now 3 screws but it´s tight and had made no more problems, yet… 25 Mph sounds good imo, but i am from...
would really appreciate any help, thx.
Your vesc is wired to charge port negative? Not main battery negative?
It´s wired to BMS C- and also Charging port - .
This BMS is different in some ways i think, anyway this is how it worked in my last setup.
Negative on the vesc should be coming directly from battery if the bms is used for charging only
This was the wiring of my old Setup which worked, as i said the BMS is kinda different.
So you’re using it for discharge?
Seems like something is cooked on the bms then if it shuts off when the vesc tries to pull amps
I thought about that too and you may probably be right, what would the vesc show if it broke ?
Are you getting any errors or faults on the vesc?
The only the it gives me is a short blue light, i´m not able to connect it via usb.
Oh it doesn’t stay on at all, I would inspect the vesc PCB, post some pics if you can
Sebike
April 7, 2018, 6:52pm
16
Is that a typo or did you set batt min to a positive value?
The
Absolute Maximum current Value was´nt there when in the Motor wizard, otherwise i would have set it down.
rich
April 7, 2018, 7:08pm
18
It’s not in the wizard because it should be 130A, that’s default, if you set it lower you’ll get faults…
You could increase Batt regen up to -12A with your 6s3p.
But this hints won’t help if you can’t connect to VESC-Tool
So the Bms should´nt be the problem because the Vesc get´s the full 24,5 V
