I installed a Metr Pro last week and when trying it out I was going super slow. I played around with profiles and came to the conclusion that I only had to change the max speed/ERPM to actually go faster or slower.
With GPS I know my top speed is 45km/h, while the Metr app shows ~90km/h.
If I set the max speed to 50 with the Metr app, I’m only going 25km/h etc…
What would be the cause of this? I checked the gearing settings and wheel diameter and those are correct.
My setup is:
Flipsky Dual Vesc 6.6
10S4P
TB 6355 190kv
14T/36T
90mm wheels
Running Sensored FOC mode
Both the Vesc and Metr are up-to-date
Any tips? Thanks in advance.
Ninja edit: Someone mentioned that it could be related to having a dual vesc?
Its because you have wrong settings in metr, go: Settings>Motor and select correct wheel size and gearing
I suggest you also go to battery and choose correct Voltage your battery have.
