VESC throttle setting
Hello, I have sk3 6374 192kv motor and VESC with gt2b remote but only the first 1/4 movement of the throttle is working Do you know why ? Thank you https://www.youtube.com/watch?v=5jmH3hEkf2c https://www.youtube.com/watch?v=P6B_rDoXJM0
probably hit max RPM for your settings or battery voltage
Me also having the same situation. But i dinnt care for it. Just press gently will used to it.
Maybe is the pulse not correct or something
This is how it is supposed to work, when you have load on the board (when you are riding it) the curve should be much more gradual.
Yeah… you need some load on that board :wink:, so it’s time to go out and try that machine… :smiley:
Thank you!
