99.9% of my build done, Vescs programmed, everything working, then I went to the bathroom and came back and found that the USB port on both vescs were burning hot, as they burned my finger. There are no leds on either Vesc and the motor doesn’t spin but the light on my receiver lights up so I know they are getting power. Any thoughts?
Also I am now noting that the drv chips on both vescs are hot, $&@#!!!. But that still doesn’t explain why the vescs don’t power on or connect to Vesc tool. They are both 4.12 from @torqueboards
Is the bleu light on ?
No, no lights at all on the Vesc… I believe I will be needing your repair service lol
Yes It is most likely the can transceiver who blowup
Ok, here is a pic, the three circled components are the ones that get really hot. I can pick out the drv chip but I’m assuming that the top chip is the can transceiver?
It sounds like a short on your 5V power supply rails
The top chip is the MCU
What brand is the VESC? Where did it come from?
Torqueboards, 4.12. I was using it with canbus, but there were no sparks or signs of anything going wrong
Short is on the 3.3v, the mcu is not powered by the 5v…
To be sure you can you check this
Thanks for the info, is there anything that could be causing this that could be an easy fix, cause tbh I’m pretty much out of funds
I’ll tag @b264 also because he was here earlier too
You can always remove the 2 CAN transceiver chip and use split PPM configuration.
@JohnnyMeduse Sweet! So I would de solder the can trasciever and run the vescs in ppm? Are there any side affects or error codes I should know about?
Edit: where is the can transceiver on the Vesc? lol
This one in yellow,
No there should not have any error code after.
Hello, sorry to summon you again @JohnnyMeduse but I removed the can chip from both vescs and one works fine, but the other I programmed regularly and it barely stutters and the yellow led on the bottom flickers really fast. Any thoughts on that?
That really weird, it could be that something else as been damage… Can you post pic or video of it?
@JohnnyMeduse It won’t let me upload a video from my phone, but here is a photo
It never turns off it just goes bright then dim
Does the motor run, does the vesc look like it work fine or it is just doing this all the time? Because it is the signal light if it sends a command to the drv the light should brighten, then dim down, and when your programming a Firmware it should flash.
You need to upload it to youtube first, then post the link.
So… the problem just randomly fixed itself lol case closed I suppose
