I got this code after 2 phases was touching while motor did a half spin … I think it means I need to replace the chip but do u know where to buy this chip?
FAULT_CODE_DRV8302
Current : 0.1
Current filtered : 0.1
Voltage : 27.38
Duty : 0.02
RPM : 0.2
Tacho : 7
Cycles running : 4
TIM duty : 966
TIM val samp : 483
TIM current samp : 22530
TIM top : 44094
Comm step : 1
Temperature : 29.73
Fault : FAULT_CODE_DRV8302
Current : 0.1
Current filtered : 0.3
Voltage : 27.38
Duty : 0.02
RPM : 0.2
Tacho : 8
Cycles running : 3
TIM duty : 991
TIM val samp : 523
TIM current samp : 22415
TIM top : 43784
Comm step : 2
Temperature : 29.67
Can be bought from Mouser or Digikey if you are in the US and willing to take challenge of resoldering. Chip is made by Texas Instruments. There is a solder pad underneath DRV chip.
Correct chip is the DRV8302DCA. You had the link to the DRV8302DCAR; I forgot what the R stands for in the product code though I did asked the question before.
the R is for the package type. In this case it mean that you need to other a minimum quantity of 2000. But there is no difference electrical difference.
