I have a VESC with a bad USB connection, I am having it replaced, but I am trying to see if I can use this until the replacement comes.
I have an ST-LINK USB connection, and I also have a HM-10 BLE. The settings on the VESC are set with UART off, using ADC for a hall sensor throttle.
Wanting to know if it might be possible to manually send commands via the ST-Link, or the possibility to use the ST-Link USB or the HM-10 as a com port for the BLDC/Vesc tool?
I’m pretty decent with a soldering iron, it’s just that the PCB copper wiring lifted from the board. I’d need to make jumpers to the resistors in order to get it working. It is something I may have to do, but it’d like to avoid having to do any microsoldering
I had the same problem, solder pads were gone… i soldered the 2 data wires directly to the usb resistors, and gnd somwhere to a gnd pin, you don’t need any other connection for normal use.
