Hi,
I got a VESC-X which I connected to the Enertion Focbox BLDC tool. The BLDC tool obviously doesn’t work with the VESC-X due to a newer firmware which is running on the ESC. What tool should I use and where do I get it from?
Hi,
https://vesc-project.com/vesc_tool
I’m pretty sure the enertion tool is only for focbox units. Try the Vedder or Acks tool.
Thanks, worked!
hit the solution on your man there dude.
Solution was: get the VESC tool from Vedder
FYI Vesc X is Focbox but anyway the newest Vesc tool will work for you.
I know that, it looks exactly the same but surprisingly didn’t work with the Enertion VESC tool, whereas my new Focbox had no issues.
