VESC-X Lab test
Jason asked me to test out the Enertion Vesc-X in a lab environment. http://www.enertionboards.com/?afmc=1o
TLDR here are the results:
was able to pull 40A at 50V before the motors would saturate and got a 30degC temperature rise. To go >40A @ 50V I would need to change up my motor jig to load up the system even more. So that’s 2000W constant, and the Vesc-X temperature only raised to 50degC. That means there’s another 50degC headroom and could probably handle up to 90-100A @ 50V constant!
Now my setup:
-15KW power supply -Master-slave motor jig, slave motor has all phases shorted together (this motor was already burnt), the master motor drives the salve -The slave motor will dynamically load up the master motor until it saturates, in this case the maximum load was [email protected]
BLDC:
FOC:
I will try to find some bigger motors to ramp up the current even more… but do i really need to?
Check your video link.
what do you mean? it’s not working? give it 2-3 mins…
ok fixed, thanks
Test in FOC-mode under heavy load please
@Blasto I agree w @E-Boarding that an FOC test would be great. Even more helpful with a 6374-sized motor at 10S.
BTW @Blasto did you solder together the three motor wires to create resistance for the other motor to push against? That’s a really clever testing jig!
I would like to see a 6374 at lower voltages, like 6-8s to see how does it manage more amps
He is already doing is test at 12S
if this vesc can take more amps I assume it would be now better suited for emountainboard use compared to the ‘‘original vesc’s’’ since a lot of ppl not recommend them for mountainboard use :wink:
Yeah, or single motor builds which happen to have some overheating problems at lower voltages with normal vescs, climbing hills or accelerating fast
Oh ha, my mistake thanks @JohnnyMeduse
@E-Boarding @treenutter Foc mode, sorry i jumped in the video, i saturated the slave motor trying to go over 40A
http://www.youtube.com/watch?v=C8nPuBvnVXM
Yes, i had a motor with two shorted phases, so i didn’t feel bad shorting the leads… up-cycling
@SirDiff i’m trying to show how much power it’s able to handle. With my current motor jig i’m able to handle 2000W no problem
I won’t start testting this and that motor… unless you guys send it to me. Next step would to crank up my motors on my jig… would it be necessary…
@Ackmaniac would your modified version of the bldc tool show the ouputted power in the real time data?
Sure, works as normal. So you can even verify that in watt mode the VESC only uses like 50% of the max watts at 50% throttle. But you only can see that when the motor has load which you are going to test as it seems.
